Question LG 49SK8100PLA stutters playing MKV files
Pebbleridge
Hi Guys,
My new LG 49SK8100PLA stutters on motion when playing MKV files.
I have been advised that it is probably due to miss matched frame rates.
Has anyone else experienced this, and is there a "fix"?
Regards,
Paul
Pebbleridge
Hi again,
I just read in another thread that there is a "PC Mode" on some LG TVs, does anyone know if it is available on the 49SK8100PLA.
Regards,
Paul
Pebbleridge
Could it be that they’re H265 encoded and not supported so the LG struggles to play with its hardware
Thanks for the suggestion but I've tried both H264 and H265 and it's the same on both file types.
It's really bad on some files but not as obvious on others, I can't figure out what the differences are.
Regards,
Paul
SeeMoreDigital
Hi Paul,
If you are able... Can you run one (or more) of your problem file(s) through an application called MediaInfo set to 'text' mode and post what it reports in full?
What delivery method are you using to access your .mkv files?
EDIT: All LG 4K UHD smart TV's from 2016 on-wards can play HEVC (h.265) content without any issues...
Pebbleridge
Hi Paul,
Hi there,
I've tried everything I can think of to play these files.
Streamed from my NAS direct to the LG.
Copied to a USB stick and plugged directly into the LG
Copied to the Hard Drive of our Humax Freesat Set top Box and played through that.
Here's what media info says
General
Unique ID : 103573720959024106093675346940675388326 (0x4DEB92B45D91EBCBF80A25BF10AE73A6)
Complete name : C:\All Data\Downloaded Videos\American.Idol.S17E02.720p.WEB.h264-TBS[eztv].mkv
Format : Matroska
Format version : Version 4
File size : 1.85 GiB
Duration : 1 h 24 min
Overall bit rate : 3 110 kb/s
Encoded date : UTC 2019-03-07 10:02:39
Writing application : mkvmerge v30.1.0 ('Forever And More') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 3 044 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.138
Stream size : 1.81 GiB (98%)
Language : English
Default : Yes
Forced : No
Audio
Format : AAC LC SBR
Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication
Commercial name : HE-AAC
Format settings : Explicit
Codec ID : A_AAC-2
Bit rate : 64.0 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 23.438 FPS (2048 SPF)
Compression mode : Lossy
Stream size : 38.9 MiB (2%)
Default : Yes
Forced : No
Any help you can offer would be greatly appreciated.
Regards,
Paul
