LG 4950 what format DVD recordable will work
Discussion in 'Blu-ray & DVD Players & Recorders' started by kwack, Apr 14, 2003.
  1. kwack
    kwack
    Sep 6, 2002
    169
    watford, england
    I currently have a LG DVD4950 model DVD player.
    I am trying to establish which format of recordable DVD will work.
    So far I have tried DVD-R and DVD+RW
    Has anyone any ideas on which ones should work or whether you can modify the player to work.
    It is a multi regoin model
    KWack
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Have a look at www.vcdhelp.com under the "DVD Players" option in the left hand side menu. You can search for your player and it will tell you what will play and what won't.
    By the looks of it you player will play some DVD-R and some DVD-RW but not DVD+RW, +R or -RAM. If you look under the comments you will see one user got the following disks to work:
    Verbatum DVD-RW
    TDK DVD-R
    Unbranded DVD-R
