lg 47lw450u expert picture settings needed
Discussion in 'LG TVs Forum' started by lukemondo, Jan 9, 2012.
  1. lukemondo
    lukemondo
    Jan 9, 2012
    5
    hello,
    I have been searching for hours to find some picture settings for my lg 47lw450u, but I can't find anything model specific, I'm looking
    for some expert settings for 2d HD, please can someone help me
  2. cleverdave2k
    cleverdave2k
    Sep 25, 2004
    438
    28
    +39
    You didnt look very far at the top of the lg section theres a thread for best settings :laugh:
    I used the expert one for the 42" on my 47" and it gives a brillaint picture
  3. lukemondo
    lukemondo
    Jan 9, 2012
    5
    I looked in their and their is only settings for a 32", also half the settings I have on my expert menu aren't even on that spreadsheet so I was hoping someone with the exact same model as me would post their best settings?
  4. cleverdave2k
    cleverdave2k
    Sep 25, 2004
    438
    28
    +39
    yeah the 32 setting are what i used i got the 47 like you try them they are spot on think the other options arent mentioned as everyone has them off as they make the range lag
  5. lukemondo
    lukemondo
    Jan 9, 2012
    5
    ok mate, thanks for your help will give them a go.
  6. lukemondo
    lukemondo
    Jan 9, 2012
    5
    did u set the tru motion to off? I have tried them and they are spot on.
  7. cleverdave2k
    cleverdave2k
    Sep 25, 2004
    438
    28
    +39
    Yeah there good setting will do us untill someone does some proper 47" settings :smashin:
    I have tru motion off seemed to blur the picture a lot when theres fast movement
