Question LG 47LA620V Not Responding to Remote
Discussion in 'LG TVs Forum' started by an999, Jun 25, 2019.
  1. an999
    an999
    Sep 22, 2013
    2
    Can anyone help with this problem?
    The TV no longer responds to the remote control.
    I have tried replacing the batteries and subsequently bought a new remote control but the TV doesn't respond to either of them.
    I've noticed that the red 'standby' light at the bottom centre of the of the edge of the tv no longer seems to appear. I'm wondering if that is the receiver for the remote and its faulty?
    Other than the above problem, the TV works fine.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,987
    Lanarkshire
    +2,612
    No, that's not the IR sensor , that's the standby LED.
    The IR sensor doesn't emit any visible light.
    You would need to get the set looked at by a professional.
  3. sagaris99
    sagaris99
    Jul 15, 2018
    679
    Berkshire
    +433
    Mis post, please delete
  4. shotokan101
    shotokan101
    Jun 16, 2009
    75,856
    33
    Glasgow
    +25,816
    Have you tried reregistering the remote?
  5. JayCee
    JayCee
    Jan 20, 2004
    23,987
    Lanarkshire
    +2,612
    The OP's model is approx 5 yrs old and uses an IR remote not Bluetooth.
  6. SeeMoreDigital
    SeeMoreDigital
    Mar 11, 2005
    2,889
    Nottingham, UK
    +781
    Indeed... The 'LA' range of TV's date back to 2013. I have an 'LN' model which is from the same time period and an 'LS' from the year before.
    Both TV's still work okay but when some buttons on their remotes started to fail I replaced them with an LG AKB75095307 model. Which, I'm happy to confirm, functions perfectly with these old TV's.
