LG 4750 multi-region
Discussion in 'Blu-ray & DVD Players & Recorders' started by HMHB, May 1, 2002.
  1. HMHB
    HMHB
    Nov 11, 2001
    27,267
    Nottinghamshire
    +6,156
    I have a cheapo LG 4750 multi-region DVD player. I've tried the multi-region hack - it asks me to input the region code - I enter 0 which means auto, it accepts it but will still not play region 1 DVDs. I'm definately doing it according to instructions. Has anyone else had this problem? Anyone got any ideas ? The DVDs definately play on the cheapo player I used to have.
    Fix for this if anyone else has this problem:-
    All the hacks listed on the internet fail to tell you to press "pause" again after the single digit region code. You need to press pause after entering zero for region free mode.
  2. curlywatts
    curlywatts
