LG 44" DLP TV RE44SZ20RD for £700 vs RE44SZ21RD
Discussion in 'TVs' started by tiggertimuk, May 25, 2005.
  1. tiggertimuk
    tiggertimuk
    I've been following the threads on DLP TVs for a while now and have decided that this is the way to go.
    I've also stumbled across a seemingly reputable dealer on E-Bay offering the RE44SZ20RD for under £700. Is this the bargain it appears or is there something I should know about this TV?
    Lastly, is there any significant difference between the model 20 and the model 21 that would make it worth paying over £1,000 for the newer model?
  2. cmt
    cmt
    Apr 4, 2005
    3,476
    +221
    as far as i know the diference in the 20 to 21 is the addition of the component input.
    I had the 21 - it was good while it lasted (just under 4 weeks) before it 'popped' and wnet back (got a panny Viera now :) ).
    I think lion bought the only good one out there as his seems to be trouble free (althought i seem to remember he bought a projector as a back-up in case it goes)
    Do a search on the model number and it will throw up quite a few threads on the subject. The main problems are the lamps going reasonably quickly (lg only g'tee the bulb for 3 months), the Power board for the bulb, some geometry problems and rainbow effects.
    But as with most forums, people only report problems and very rarely report the non-existance of problems (if that makes sense!)
    cmt
  3. Razor
    Razor
    Dec 15, 2004
    37,550
    2
    +12,509
    I'd save my cash and buy a proper DLP TV instead.
  4. The-Stranger
    The-Stranger
    Apr 28, 2005
    49
    currys have the 21 model for £999 now
    personally speaking from experience, the tv is excellent, picture is good quality etc
    however, it only lasted for 14 months before breaking - if you buy one - get the extended warranty - domestic and general do a annual one for £50
    considering the cost of repair for bulb and board is £400-£500- well worth it
    i am going to buy warranty once LG have repaired mine
    good luck
