LG - 42PX5D Input switching problems
Discussion in 'LG TVs Forum' started by Jaffa King, Jan 4, 2007.
  1. Jaffa King
    Jaffa King
    Please help, i brought an LG 42PX5D just 5 months ago and lately it seems to have developed a fault.
    The problem is that i have many different components connected Sky (AV-1), X-Box (AV-2), DVD Player (HDMI) and X-Box 360 (Component) and when i switch from one to the other the TV occasionally freeze's/crashes. The green light stays on but the "input" doesnt change. The only way to recover it seems to be pull the plug and start again (when it will be fine untill put back into standby)
    This fault only happens occastionally which makes it even more frustrating. If anyone has any information about this problem i would love to hear it.
    ROCK-ON!
  2. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
    Jaffa
    Have a read of the 42PCD1a forum its been mentioned in their i think if you go straight to the last page stainway has posted about it
    If i remember correctly something to do with scart leads and pin 8 sendinding 12 volt signals down the line
    regards
  3. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
