LG 42PX5D - Another silly question
A
Altern8
hi folks,
Having had my plasma for a couple of days now, I have a small annoying problem. Hope someone can help to solve it.
Is there any way to turn the tv off? Sounds a silly question, I know. When I hit the on/off button on the tv, it goes into 'standby' mode, and a little red light appears, the same happens when I use the remote controll.
Is there anyway to turn the tv off full stop, apart from taking the plug out of the mains socket, seems to a waste of electric overnight.
Kev
stuart2
Established Member
In my experience on/off switches on tv's seem to be the first item to go wrong. It cost me £125 to fix a switch on a Sony tv a couple of years ago. I now turn it off with the remote now which leaves it on standby, unless I am going away for a day or more. Standby power consumption is normally less than 2 watts.
How is the LG by the way? I am interested in getting one but I believe it does not have audio out on it, correct?
kjt2004
Established Member
Like you i was concerned at leaving it in standby all the time , obviously allows for downloads on the digital tuner in standby though remember.
However I decided to re route the power cable to its own supply plug so i can at the flip of a switch just turn off the plasma completely.
If you look at the pics to i have taken the supply to the plasma from the outlet socket to the right and all other equipment is fed via a socket behind the cabinet.
In answer to the other query the 4DV does have audio out i have it routed through my sony S550 amp, so i guess the 5 does also
regards
C
clydethelab
I'll confirm that it has left and right audio output. You can turn the inbuilt speakers off and feed the audio output via an amp.
A
Altern8
Hi folks,
Many thanks for your replys, I am very grateful. Will try and post a pic if I can.
Kev
S
Symo
Is it possible to feed the inbuilt left/right speakers from an amp so as to avoid having two sets of fronts?
Hope this makes sense;)
Symo
kjt2004
Established Member
No
But why would u want to?
As you can turn them off in the menu and just use your surround fronts
hope that makes sense
regards
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
