LG 42PX11 audio out
Discussion in 'Plasma TVs' started by mpadgett, Dec 20, 2004.
  1. mpadgett
    mpadgett
    Is there any way that i can get the audio out of the LG. basically the audio from the speakers isnt suffering a sync problem. (i think that the LG has a built in audio delay - selectable from service menu).
    I would like to take the sound that the LG uses and send that through my amp rather than via optical out of the sky plus box to the amp.
    hope this makes sense.
    cheers
  2. dacres
    dacres
    Jan 16, 2004
    27
    SCART to RCA cable sends TV sound from LG -AV2- to any amplifier.
  3. mpadgett
    mpadgett
    what does this mean.. does this mean that it is possible to capture the sound from the tv and send it to the amp. or is it just capturing it from the original source via the scart. I appologise for my greeness this is all quite new to me.
    thanks
  4. andypo
    andypo
    Feb 8, 2005
    447
    28
    norwich
    +26
    You can get audio out by putting sart socket in either av 1 or 2 then putting phono leads into amp
