LG 42PX11 and s-video
Discussion in 'LG TVs Forum' started by stexxe, Mar 22, 2005.
  1. stexxe
    stexxe
    Hi all,
    I have bought the LG 42PX11 and tried to connect this to a PC using the S-VIDEO to watch a DVD. The problem is that all the images seems solarized, like a 32bit image viewed on a 16 or 24bit screen :confused:
    Someone have any idea?
    Stexxe
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    can you try using a vga connection?
  3. mannyo
    mannyo
    Feb 6, 2005
    758
    28
    Blandford Forum
    +77
    Connect to the pc using either dvi or vga for a much better clearer and sharper image.
  4. stexxe
    stexxe
    Ok, but why the s-video cause this problem?
    Someone with the same TV reported this problem?
    Stexxe
  5. Teccy Toker
    Teccy Toker
    Dec 16, 2004
    68
    Bought one of these sets in dec last year...both s-video sockets failed, set was replaced 10th march and the s-video sockets lasted 1 day (the mico dvd recorder connected with s-video had worked with 3 other TV's fine)...LG are 'looking into it' duh !
    TT
  6. stexxe
    stexxe
    The s-video socket "failed" means that simply doesn't work or do you have the same solarization problem?
  7. Teccy Toker
    Teccy Toker
    Dec 16, 2004
    68
    my old set was firmware 3.17 and had terrible solarization and both s-video sockets failed after a few days...the new one is firmware 5.13 and the piccy is much better (still not perfect) and the s-video sockets lasted one day.
    Still can't get the teletext to werk right (can't go through the sub pages..grrrrr !)
    TT
  8. stexxe
    stexxe
    Thanks TT, but how can I check the firmware versions, and also how can I update it?
    But now, do you have your TV or is on the hand of LG for 'looking into it' ?
    Anyway I will have sometime saturday to check the VGA connection, have you tried this?
  9. Teccy Toker
    Teccy Toker
    Dec 16, 2004
    68
    You need to go into the service menu (press and hold the menu button
    on the telly and also press and hold the remote menu button at the same time....after a few seconds the service menu appears with the firmware version.....to get out of the service menu just press the remote menu button till the service menu dissappears).
    The LG service people have to upgrade the firmware...:(
    I still have my telly.....the LG tech peeps are meant to be keeping me informed....yeah right !.
    As to the VGA...I have my telly connected to a Radeon 9800 pro graphics card 2nd monitor port on vga at 1024 x 768 @ 85hz...my pc screen rez...the telly scales it down fine, and the piccy is quite good (havn't got a long enough DVI cable to try DVI though).
    TT
  10. stexxe
    stexxe
    Uhmm so I need to contact LG service people... first I try to use a different s-video source.
    About the configuration, usign the s-video I have tried the resolution of 1024 x 768 @ 60Hz but there was some sizzle images. I changes the resolution on 800x600 and works without problem!
    This saturday I will also buy a VGA cable... :)
    Thanks a lot for your help!
