LG 42PC3D loud volume on lowest setting
Discussion in 'LG TVs Forum' started by fretman, Jan 1, 2007.
  1. fretman
    fretman
    I have the LG 42PC3D. I have it on the lowest setting at 1. The volume is quite loud even at this setting. There's not much of a difference if any when I set it at 2. When I set it at 0 then the TV is in mute mode.
    Is there a default volume setting on the TV itself that can be adjusted so that when I have the volume at 1 it's not as loud as it is now?
    Any suggestions? Thanks.
