Quantcast
LG 42LW650T or 42LW550T what's the difference?
corblimey
I've decided to go for a 42" LG but what's the difference between the 650 and the 550?
I see the contrast ratio and the motion clarity index is better on the 650 but all the other differences seem superficial.
Are the differences worth bothering about?
kenfowler3966
As you can sometimes get the 650 cheaper anyway, I would go for that if you can. 200hz, instead of 100hz, and I think the built in spealers are also slightly better. I have the 650 and have been happy with it since April.
corblimey
Yeah, that's odd about the pricing. The 550 is more expensive than the 650 in the likes of Comet, Currys, Dixons, etc. Not sure why that is.
C
cab50
any ideas why it only appears to be available from curry's
trying to get the 650 on amazon as it is just easier if there are issues and delivery is free etc.
Anyone ever seen it on amazon?
Gambit1977
Got the 550 on Amazon last week...took 4 days to leave the depot, then another 3 to arrive. Was NOT happy. I'm a prime customer too!
C
cab50
ah - not good! out of interested did you consider the 650 and why did you not go for it?
Gambit1977
Good win on the football over Christmas, along with the fact I got vat off on amazon making the 550 £665. Was originally just getting a 450.
dennett316
I believe the 650 sets are exclusive to Currys/Dixons, they are basically slightly souped up 550 models. Probably why they're cheaper as well, not many seem to like Currys customer service so perhaps the lower prices are to entice you in?
windfall
You're Right!
When Sky were doing the rebate there was mention that certain sets were only available in DSG and one particular set was only available in Richer Sounds.
Tone
Similar threads
