LG 42LW5300 LED 3d - Need a little help
Discussion in 'LG TVs Forum' started by getonit187, Jul 29, 2012.
  1. getonit187
    getonit187
    Jul 29, 2012
    Ok so i found this lg 42LW5300 1080p led 3d tv for a good price. The only thing is that the frame has some damage. a crack on the front left side and its a little bent and loose on the back.The screen is fine. My question is do you think i should still buy it ? would the frame being damaged eventually fall off or something ? How much would it be to get the frame fixed ?
    If someone could please help me out with this i would really appreciate it.
    and the pics are attached ... :confused:
