LG 42LW450U dts sound ?
Discussion in 'What Is The Best TV For You?' started by jjp2701, Jan 12, 2012.
  1. jjp2701
    jjp2701
    Jul 25, 2007
    494
    manchester
    +10
    i am thinking of buying one of thes tvs for 519 pound tommorow from a clearance centre
    but i think it doesnt do dts sound, so if i put a optical lead through my blu-ray surround sound player annd hdmi into my tv from my ps3 and play a blu-ray 3d film with dts inside, will that still output dts sound through my surround sound amp ?
  2. mikej
    mikej
    Aug 1, 2005
    931
    43
    +97
    Your question is confusing, but if you're asking whether you can pass DTS sound via this route : PS3-(HDMI)-TV-(Toslink optical)-AV amp, then I suspect the answer is no.
    As you're asking this question, I'm presuming that your AV amp does not support HDMI ?
    If it doesn't, can you not connect the PS3 direct to the AV amp via a Toslink optical cable ?
  3. jjp2701
    jjp2701
    Jul 25, 2007
    494
    manchester
    +10
    yes i can connect my ps3 to my optical out socket on my bd surround sound amplifier
