LG 42LN575S or Toshiba 40TL938?
Discussion in 'What Is The Best TV For You?' started by cloaked, Aug 24, 2013.
  1. cloaked
    cloaked
    Aug 24, 2013
    5
    Hello,
    I'm new on the forum and i need your help. I think I'm finally ready to make a jump from crt to something newer :) but I'm in a bit of a dilemma since i live in Croatia and there aren't many reviews of the models which you can buy. Bottom line is i need you to help me choose between LG 42LN575S and Toshiba 40TL938. The price is more or less the same, toshiba has 3d, lg doesn't. 3d is not a must for me, so i am willing to sacrifice toshibas 3d if the lg has better picture quality or some other perks, but it would be a nice feature to have if overall quality is on par. I heard lg's smart tv is better than toshibas' and although i am tech savvy, I am more or less clueless when it comes to new tvs.
    edit: If i'm getting this right, the toshiba has edge lighting and lg local dimming. Does that mean a significant difference in picture quality considering the improvements in edge lighting over the years?
    Can you give me some pros and cons for both and help me decide. Thank you in advance!
    40TL938 - Toshiba
    LG 42LN575S (its in croatian but its more or less self explanatory)
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  3. cloaked
    cloaked
    Aug 24, 2013
    5
    Can i please get some info by anyone, i kinda want to buy it tommorow :)
