Lg 42lg5010
Discussion in 'LG TVs Forum' started by Smiley Soundz, Mar 10, 2013.
  1. Smiley Soundz
    Smiley Soundz
    Mar 10, 2013
    2
    I wonder if any one can tell me what the problem is with my LCD tv. Was working perfectly until one day the screen displays images 'very light' & hard to make out. I have a couple of pictures I took to show the fault.
    [​IMG]
    [​IMG]
    Any help would be greatly appreciated. I have just checked all connections after removing the rear panel & all seem fine. No obvious faults visible. Capacitors have no signs of bulging at the top. Removed T-Con board to check connectors & all fine. No unusual noises coming from anything. The picture's above were taken in my garage in the dark so their is plenty light coming from the back-lights so I think they are fine.
    Just wanted some guidance on what component is most likely at fault before buying on E-Bay.
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    Bradford, West Yorkshire.
    +325
    Don't waste your money. 99% certain to be the panel itself. Very common fault on this series.
  3. Smiley Soundz
    Smiley Soundz
    Mar 10, 2013
    2
    After doing a bit of web searching I thought that might be the case. Cheers for your reply.
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    +325
    You're very welcome.
    It's nice for a new member to thank someone for their advice!
