Hi mates,
i have 42ld550 one morning I try to start my LG TV I got this screen pic:
I got this message when I am connecting it with terminal:
[ 0.265000] [<8047883c>] get_sb_bdev+0x108/0x1dc
[ 0.265000] [<804bc160>] squashfs_get_sb+0x20/0x2c
[ 0.265000] [<80476f94>] vfs_kern_mount+0x68/0xc4
[ 0.265000] [<80477054>] do_kern_mount+0x54/0x110
[ 0.265000] [<80492e30>] do_new_mount+0x78/0xe4
[ 0.265000] [<80493d1c>] do_mount+0x1ac/0x1f0
[ 0.265000] [<80493dfc>] sys_mount+0x9c/0x1c0
[ 0.265000] [<80903ff4>] mount_block_root+0x13c/0x2e8
[ 0.265000] [<80904394>] prepare_namespace+0x178/0x1b0
[ 0.265000] [<80903550>] kernel_init+0x2f4/0x330
[ 0.265000] [<80405750>] kernel_thread_helper+0x10/0x18
[ 0.265000]
[ 0.265000]
[ 0.265000] Code: 00802821 1280017f 8fa30020 <92a20000> 2694ffff 26b50001
02421004 02629821 081460b2
[ 0.500000] Kernel panic - not syncing: Fatal exception in process
[ 0.506000] Rebooting in 1 seconds..<7>[ 0.000000] Linux version 2.6.26 (d
y.jin@swfarm-l12) (gcc version 4.3.2 (crosstool-NG-1.4.0) ) #163 PREEMPT Mon May
3 09:30:20 KST 2010
[ 0.000000] LINUX started...
[ 0.000000] DDR Size is 256MB
[ 0.000000] console [early0] enabled
[ 0.000000] CPU revision is: 00019554 (MIPS 34K)
[ 0.000000] Begin Titania3_setup
[ 0.000000] Set the MIU size in the 256MB DDR
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 009dd000 @ 00000000 <7>(reserved)
[ 0.000000] memory: 001e3000 @ 009dd000 <7>(usable)
[ 0.000000] memory: 01573000 @ 0578d000 <7>(usable)
[ 0.000000] memory: 03330000 @ 44cd0000 <7>(usable)
[ 0.000000] Malformed early option 'lcdmodels'
[ 0.000000] Wasting 80800 bytes for tracking 2525 unused pages
[ 0.000000] Entering add_active_range(0, 0, 2525) 0 entries of 256 used
[ 0.000000] Entering add_active_range(0, 2525, 3008) 1 entries of 256 used
[ 0.000000] Entering add_active_range(0, 22413, 27904) 1 entries of 256 used
[ 0.000000] Entering add_active_range(0, 281808, 294912) 2 entries of 256 use
d
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 131072
[ 0.000000] Normal 131072 -> 131072
[ 0.000000] HighMem 131072 -> 294912
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0 0 -> 3008
[ 0.000000] 0 22413 -> 27904
[ 0.000000] 0 281808 -> 294912
[ 0.000000] On node 0 totalpages: 21603
[ 0.000000] DMA zone: 1024 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 7475 pages, LIFO batch:0
[ 0.000000] Normal zone: 0 pages used for memmap
[ 0.000000] HighMem zone: 1280 pages used for memmap
[ 0.000000] HighMem zone: 11824 pages, LIFO batch:1
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag
es: 19299
[ 0.000000] Kernel command line: root=/dev/mtdblock3 lginit=/dev/mtdblock4 ro
otfstype=squashfs host=saturn7 noinitrd ramdisk=0 console=ttyS0,115200n8r ip=165
.186.175.92:192.168.0.1:192.168.0.10:192.168.0.1:255.255.255.0 appxip_addr=0x6d0
0000 fontxip_addr=0x0 xipfs=19 quiet_app loglevel=0 panic=1 lcdmodels memsize=12
8 boot1stver=3.00.00 boot2ndver=0.01.05 bt=0 dvr=0 lpj=167424 start_kernel=1783
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32
bytes
[ 0.000000] Writing ErrCtl register=0005587b
[ 0.000000] Readback ErrCtl register=0005587b
[ 0.000000] PID hash table entries: 128 (order: 7, 512 bytes)
[ 0.000000] CPU freq count = 252000000
[ 0.000000] CPU frequency 504.00 MHz
[ 0.000000] console handover: boot [early0] -> real [ttyS0]
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.106000] Memory: 67024k/76312k available (2794k kernel code, 9268k reserve
d, 2336k data, 116k init, 52416k highmem)
[ 0.106000] totalram_pages : 16761, num_physpages : 19078
[ 0.106000] SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, No
des=1
[ 0.106000] Calibrating delay loop (skipped)... 334.84 BogoMIPS preset
[ 0.106000] Mount-cache hash table entries: 512
[ 0.110000] net_namespace: 192 bytes
[ 0.110000] NET: Registered protocol family 16
[ 0.132000] SCSI subsystem initialized
[ 0.133000] usbcore: registered new interface driver usbfs
[ 0.134000] usbcore: registered new interface driver hub
[ 0.135000] usbcore: registered new device driver usb
[ 0.146000] NET: Registered protocol family 2
[ 0.155000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.156000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.156000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.156000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.156000] TCP reno registered
[ 0.159000] NET: Registered protocol family 1
[ 0.162000] highmem bounce pool size: 64 pages
[ 0.162000] squashfs: version 3.4 (2008/08/26) Phillip Lougher
[ 0.163000] NTFS driver 2.1.29 [Flags: R/O].
[ 0.163000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.163000] msgmni has been set to 28
[ 0.164000] io scheduler noop registered (default)
[ 0.165000] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing
disabled
[ 0.169000] serial8250: ttyS0 at I/O 0xbf201300 (irq = 8) is a 16550
[ 0.180000] loop: module loaded
[ 0.180000] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet dr
iver
[ 0.181000] usbcore: registered new interface driver pegasus
[ 0.181000] rtl8150: rtl8150 based usb-ethernet driver v0.6.2 (2004/08/27)
[ 0.181000] usbcore: registered new interface driver rtl8150
[ 0.182000] usbcore: registered new interface driver asix
[ 0.183000] Driver 'sd' needs updating - please use bus_type methods
[ 0.185000] Disable power down for H.264 firmware
[ 0.185000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128
MiB 3,3V 8-bit)
[ 0.185000] redirect_size = 400000, redirect_start = 7c00000
[ 0.186000] Loading nand bad block info(00000000+00020000)...
[ 0.194000] Mstar nand-flash partition definition
[ 0.194000] mtd info : # of partition = 25
[ 0.194000] Creating 25 MTD partitions on "NAND 128MiB 3,3V 8-bit":
[ 0.194000] 0x00000000-0x00020000 : "bbminfo"
[ 0.197000] 0x00020000-0x000a0000 : "boot"
[ 0.199000] 0x000c0000-0x000e0000 : "mtdinfo"
[ 0.201000] 0x000e0000-0x007e0000 : "rootfs"
[ 0.203000] 0x007e0000-0x00840000 : "lginit"
[ 0.205000] 0x00840000-0x008c0000 : "boot"
[ 0.208000] 0x008c0000-0x008e0000 : "crc32info"
[ 0.210000] 0x00900000-0x00920000 : "model"
[ 0.212000] 0x00920000-0x009a0000 : "logo"
[ 0.214000] 0x07860000-0x07900000 : "cmndata"
[ 0.216000] 0x07900000-0x07980000 : "nvram"
[ 0.219000] 0x07980000-0x07a80000 : "user"
[ 0.221000] 0x009a0000-0x00da0000 : "ezcal"
[ 0.223000] 0x00da0000-0x016a0000 : "estream"
[ 0.225000] 0x016a0000-0x01920000 : "opsrclib"
[ 0.228000] 0x01920000-0x01c40000 : "kernel"
[ 0.230000] 0x01c40000-0x02640000 : "lgapp"
[ 0.232000] 0x02640000-0x03840000 : "lgres"
[ 0.235000] 0x03840000-0x04240000 : "lgfont"
[ 0.237000] 0x04240000-0x05940000 : "addon"
[ 0.240000] 0x05940000-0x05c60000 : "kernel"
[ 0.242000] 0x05c60000-0x06660000 : "lgapp"
[ 0.244000] 0x06660000-0x07860000 : "lgres"
[ 0.247000] 0x008e0000-0x00900000 : "cert"
[ 0.249000] 0x07a80000-0x07b20000 : "authcxt"
[ 0.251000] mod_nand_init is invoked
[ 0.251000] GE driver inits
[ 0.251000] GOP driver inits
[ 0.251000] REG_MIPS_BASE 0xBF200000
[ 0.251000] mod_iic_init is invoked
[ 0.253000]
[ 0.253000] Check model option
[ 0.253000] BOOTSTRAP 6d(4)
[ 0.253000] Display Type : LCD
[ 0.253000] URSA3 Internal
[ 0.253000] Mini LVDS
[ 0.253000] DDR 256
[ 0.253000] FHD Panel
[ 0.253000] GIP Panel
[ 0.253000] LCD Panel
[ 0.257000] [SCALER][000157] _mod_scaler_init
[ 0.257000] [MADMOD][003318] _mod_mad_init is invoked
[ 0.257000] init 160
[ 0.257000] [HVDMOD][000871] H264 bit-stream buffer addr 0xc1b00000; size
4194304
[ 0.257000] CI driver inits
[ 0.257000] [TTX_DRV][00503]init 170
[ 0.257000] [VE_DRV][00488]MDrv_VE_Module_Init is invoked
[ 0.257000] [VE_DRV][00492]call register_chrdev_region
[ 0.257000] [VE_DRV][00518]Init VE successfully
[ 0.257000] MDrv_CC_Init
[ 0.257000] init 172
[ 0.257000] <MHal_JPD_Initialize>
[ 0.257000] [DEMOD_DRV][00321]init 245
[ 0.257000] [MPIF][000126] MDrv_MPIF_ModuleInit
[ 0.257000] [BDMA_DRV][00959]init 248
[ 0.257000] Get the MIU1 Base Addr from 256M DDR
[ 0.259000] TCP cubic registered
[ 0.259000] NET: Registered protocol family 17
[ 0.259000] ieee80211: 802.11 data/management/control stack, git-1.1.13
[ 0.259000] ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@li
nux.intel.com>
[ 0.259000] ieee80211_crypt: registered algorithm 'NULL'
[ 0.259000] ieee80211_crypt: registered algorithm 'WEP'
[ 0.259000] ieee80211_crypt: registered algorithm 'CCMP'
[ 0.259000] ieee80211_crypt: registered algorithm 'TKIP'
[ 0.261000] Adding user_initcall[0] = 0x8057bd98
[ 0.261000] Adding user_initcall[1] = 0x8057bda4
[ 0.261000] Adding user_initcall[2] = 0x8057ecc0
[ 0.261000] Adding user_initcall[3] = 0x805ae43c
[ 0.265000] CPU 0 Unable to handle kernel paging request at virtual address 6
60a95b0, epc == 805182f4, ra == 805182a8
[ 0.265000] Oops[#1]:
[ 0.265000] Cpu 0
[ 0.265000] $ 0 : 00000000 00000000 00000001 86939eff
[ 0.265000] $ 4 : 0000007e 0000007e 00008913 000000ff
[ 0.265000] $ 8 : 8608d401 d005b52c 86939efe fff1f295
[ 0.265000] $12 : 00000036 00130c55 d005b000 00000c9b
[ 0.265000] $16 : 00000000 d005b000 00000005 00000015
[ 0.265000] $20 : 1ffe3eb0 660a95b0 869320cc 00000101
[ 0.265000] $24 : 000002e4 869320cc
[ 0.265000] $28 : 86818000 868199e0 00000000 805182a8
[ 0.265000] Hi : 00000000
[ 0.265000] Lo : 00000000
[ 0.265000] epc : 805182f4 zlib_inflate+0x984/0x1270 Not tainted
[ 0.265000] ra : 805182a8 zlib_inflate+0x938/0x1270
[ 0.265000] Status: 11008c03 KERNEL EXL IE
[ 0.265000] Cause : 00800008
[ 0.265000] BadVA : 660a95b0
[ 0.265000] PrId : 00019554 (MIPS 34K)
[ 0.265000] Modules linked in:
[ 0.265000] Process swapper (pid: 1, threadinfo=86818000, task=86814000, tls=
00000000)
[ 0.265000] Stack : 00000002 d005b28c 00000013 8049f5d4 d005b054 00000000 000
00060 00001d1c
[ 0.265000] 86939eff d005b054 d005b2ec d005b050 d005b068 d005b06c d00
5b52c 86819a1c
[ 0.265000] 00000000 86932000 00000060 00000001 86869404 00000002 000
00134 869320cc
[ 0.265000] 00000194 804bcaa8 0fcb9440 00000000 80769d08 80948b20 000
00020 0000000a
[ 0.265000] 80950194 00000000 00001809 00000194 86869400 869320a4 006
022ca 00000000
[ 0.265000] ...
[ 0.265000] Call Trace:
[ 0.265000] [<805182f4>] zlib_inflate+0x984/0x1270
[ 0.265000] [<804bcaa8>] squashfs_read_data+0x53c/0x7a8
[ 0.265000] [<804bddd8>] squashfs_cache_get+0x250/0x47c
[ 0.265000] [<804be074>] squashfs_get_cached_block+0x64/0x170
[ 0.265000] [<804bf498>] squashfs_read_inode+0x190/0x1328
[ 0.265000] [<804bda64>] squashfs_fill_super+0xbdc/0xd00
[ 0.265000]
[ 0.265000]
[ 0.265þ[ 0.265000] Oops[#1]:
[ 0.265000] Cpu 0
[ 0.265000] $ 4 : 0000007f 0000007f 0000850d 000000ff
[ 0.265000] $20 : 1ffe3eb0 660a95b0 869360cc 00000101
[ 0.265000] $24 : 000002e4 869360cc
00000000)
00060 00001d1c
5b52c 86819a1c
[ 0.265000] 00000000 86936000 00000060 00000001 86869404 00000002 000
00134 869360cc
00020 0000000a
[ 0.265000] 80950194 00000000 00001809 00000194 86869400 869360a4 006
022ca 00000000
[ 0.265000] ...
[ 0.265000]
[ 0.265000]
3 09:30:20 KST 2010
[ 0.265000]
[ 0.265000]
3 09:30:20 KST 2010
d
es: 19299
bytes
des=1
disabled
iver
MiB 3,3V 8-bit)
[ 0.253000]
[ 0.253000] DDR 256
4194304
nux.intel.com>
[ 0.265000] Cpu 0
00000000)
00060 00001d1c
5b52c 86819a1c
00134 869320cc
00020 0000000a
022ca 00000000
[ 0.265000] ...
[ 0.265000]
[ 0.265000]
[ 0.265000] Cpu 0
00000000)
00060 00001d1c
5b52c 86819a1c
00134 869360cc
00020 0000000a
022ca 00000000
[ 0.265000] ...
[ 0.265000]
[ 0.265000]
3 09:30:20 KST 2010
