Osmasbeenfired
This is for all EU tv's with the model number LG 42LD450-ZA.
My method, buy a cheap one4all urc 3920 tv remote from tesco for 8.99.
Download the latest firmware from the LG website should be 03.03.34.
Place it in a folder called LG_DTV and put that onto any usb stick, then plug it in to your tv. press menu on your LG remote, select but dont press- options. then press 'FAV' 7 times slowly it will then allow you to install the Update with options.
now that is all done we can get on with the one4all remote programming.
Press TV
Press and hold the magic button until it flashes twice
Press 994
Press the magic key
press the ch+ key
Press the magic key (the light will hold for a second longer).
Now the remote is programmed.
ch+ is now your service menu button
Press ch+ to bring up the service menu password
(Don't forget you might need to press the magic button again to use the service button).
When a password box appears with four **** you will input 0413
Choose tool 2 scroll down enable divx play back.
Dont **** around with all the settings, youll just break your tv.
If you have the wired headset error or like me you broke the headphone jack on the side and your tv has no volume then again tool 2 scroll down and disable headphones. by disable i mean change from 1 to 0.
thanks for reading this
Press TV
Press 994
Press the magic key
press the ch+ key
