LG 42LB1DB Discrete Codes
Discussion in 'Home Cinema Control & Remote Controls' started by danbl, Apr 28, 2007.
  1. danbl
    danbl
    Nov 5, 2006
    208
    +8
    Does anyone have the hex codes for the LG LB1DB series? Particularly the HDMI input codes.
    I have a harmony and none of the input commands change the TV to HDMI 1 or 2 :(
  2. Adamh4
    Adamh4
    Jun 20, 2006
    129
    3
    Paignton
    +20
    Try www.remotecentral.com
    Most manufacturers use the same discrete codes across different models, I would be surprised if you don't have any luck.
    cheers, Adam.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That's a very common problem. AFAIK there are no discrete codes for LG, it's why they are not popular on the AV installation scene.
  4. danbl
    danbl
    Nov 5, 2006
    208
    +8
    This is my second LG TV, and they have both had discrete codes for everything with the exception of HDMI on this set. Toshiba is the only big brand I know of that have NO discrete codes
