LG 42 PX3rv 850 x 480
Discussion in 'Plasma TVs' started by wolff, Sep 19, 2005.
  1. wolff
    wolff
    Jul 25, 2005
    28
    3
    Can anyone point me in the right direction - tryin to connect my PC to this Plasma and have no problem on VGA, Svga, Xga etc - I have a Raden X800 pro and can use the 850 x 480 (std on the driver for the radeon) setting on my projector - but the plasma refuses to see it
    There is a VGA option on the plasma that allows you when you use 640 x 480 resolution to to go to the 852 or the 850 resolution but when you set this all it seem to do is rescale the picture.
    the manual clearly states the plasma should have no problems with this res
    Any one had this problem ? any solutions ?
  2. wolff
    wolff
    Jul 25, 2005
    28
    3
    Anyone
    Connected up this Plasma to HTPC ?
