Hi,I was wondering what is the advantage of using interleave or checkerboard over SBS? Are interleave and checkerboard both full 1920x1080@60 unlike SBS which is 960x1080@60?
I see.
By their names like interleave and checkerboard and their icons on TV's 3D menu, it looks like both these 3D types would also reduce screen resolution by half just like SBS. In interleave, alternate scanlines are displayed and in chckerboard, alternate horizontal and vertical pixels are displayed.
If I'm not mistaken, the maximum bandwidth supported by current generation HDMI is 1920x1080x2 @ 24 Hz. So it would be interesting to know how they manage to improve picture quality using interleave and checkerboard using this limited bandwidth.
BTW, I have a 32LW4500 and I use 3DTV Play to play games at 720p@60. Of course 1080p@24 is unplayable. I will now go ahead and give Tridef a try for SBS and interleave and see if I notice any difference.
Mocca,
I also play 3D movies through my PC and everything is working quite well right now except for 1080p 3D gaming. So I am a little cautious to use Zalman EDID. Will frame-packing be disabled if I use Zalman EDID? How do I undo this EDID thing if I want to experiment but then want to go back?
Is TriDef's "Line Interlaced (Reversed)" mode the same as 3DVision Interleaved with Zalman's EDID?
I tried that TriDef's "Line Interlaced (Reversed)" mode in Trine 2 and I agree that picture quality is much better than 3DTV Play's 720p@60. However performance in terms of FPS is not as good.
The strange think is that the TV did not display its regular 3D notice when 3D content is played neither did I have to select any of the 5 2D to 3D settings like SBS, top-down, checkerboard, interleaved, etc. But the image is clearly in 3D when I put on glasses. When I press info button on TV remote, it says, 1080p 60 Hz but TV does not know that it is playing 3D content. Can it truly be considered 1080p@60 gaming in 3D? Can someone try this TriDef's "Line Interlaced (Reversed)" mode on their passive 3DTV and let me know what they think?
The Reverse interlaced will correct the depth if you need to turn glasses upside down.
The best thing is that I did not notice any colorbug.
Sorry, ignore my last message. I forgot to restart my PC. After restarting, it seems to be working alright although I have to wear glasses reversed. Is there any solution to eye-reversing and audio through HDMI?
Ok I tried Acer EDID which fixes audio problem but it has colorbug. Now what?
I seem to have good news for interleaved 3d with a pc input
This is tested as working with a 47lk950u 100% everytime!
The old 42lw450u allso had this bug but it seemed to work when it wanted, i think i was forgetting a major factor as if i do not do it in sequence the bug does'nt work.
It's was reported by me and a few other users that every now and again the sharpness settings from a none " pc label " would be carried over when enabling a " pc label " giving 99% working zero lag interleaved 3d.
I have confirmed the following many times and will get a youtube video up tomoz proving this super bug, as it was possible on a lw450u it may be possible on any lg set.
For a nvidia card you will need a edid mod with zero extension bloc as this will clear the colour ghosting.
As amd reads lg's faulty edid? even worse than nvidia then you will not need a edid mod as you will only have the clear ghosting?
1) First change your isf expert and game sharpness setting in the none PC LABEL to clear the clear ghosting, i choose a label to my right wich is hd dvd (not game label ).
2) start your 3d game so you can see the clear ghosting dissapear ,once this is done change back to PC LABEL!!!!
3)Select GAME mode with AV button on tv controller!!!!!!!!!!
4) Press input on controller and select dvd hd or what ever is the next label from pc label, i choose a none game label, use a label directly next to pc label!
5)Press menu on tv controller and goto display setings or what ever it's acalled for you and select your pre made isf expert setting, NOTICE the clear ghosting dissapear.
6) Press exit on controller
7) Press input and change back to pc label, should be one press of left or right , NOTICE if you are lucky you are now have a lesser lag pc label and clear ghosting is cleared up 99% making games 100% playable
I've turned the tv on and off many times, this method of exact button presses creates a carry over of settings bug or something along those lines.
Is there an option for this do you know, from memory when i used the service menu i did'nt notice a option for this?If mocca sais that Trumotion makes colorbug also on Toshiba, wouldn't be a posibility to compleetly disable trumotion on LG from service menu?
I personally don't know if there is an option for this. I only enabled THX in the service menu and didn't explore because i'm afraid not to do something stupid. But I think there might be ppl more experienced that could know.
Mocca,
Have you tried 55LM760T EDID with Nvidia 3DTV Play? Any idea where can we download that EDID from?
