LG 37LP1D Mounting question
Discussion in 'Home Cinema Buying & Building' started by Roguevfr, Mar 8, 2006.
  1. Roguevfr
    Roguevfr
    Nov 14, 2005
    19
    3
    Hi, I've just bought an Alphason AG94 stand for my 37LP1D , can anyone give me some pointers on how to mount the tv to the brackets - they have provided a bewildering amount of various screws and fixings. Also, how is the tabletop stand from the tv removed ?
    Thanks in anticipation, Rod
  2. leaky55
    leaky55
    I have this stand on a RZ-37LZ31 TV. The desktop stand has 4 screws at the back and then the stand slides out from the bottom. For the stand, I put the TV up against a sofa, then I built the 4 metal brackets into a rectangle. I then adjusted this until it lined up with the holes on the back of the TV. I then screwed this onto the TV and then used polystyrne from the TV packaging on the top shelf of the AG94 to hold the TV at the right height. Then I bolted this lightly to the stand upright, adjusted it and then tightened once in the right position.
