LG 37LC55 anyone got any info on it?
B
baritoni
Well it depends how you look at it:
LC55:
-Better SD (including DVD) picture
(as most will view SD at least 90% or maybe even 100%)
-cheaper
-37" 6ms
LF65/66:
-Better 1080p when viewed from 3ft
-Better resolution for PC-use
-Pure black technology
-37" 8ms
At size of 37" Full-HD does not make much of a difference as a TV. For PC-use from 3ft.
edit:eek:oooh the spelling and some more info
L
lemel
Been looking at the LG37LF66 today....it looks good and at £699 seems good value for money considering the full 1080p.
Trouble is there is so little info out there on it, and my question is is it really worth investing a little more in a 1080 set...if your not planning to use HD-DVD or Blu-ray?? Over a known good picture quality set like the samsung LE37R87, with has 1366x768 at £100 less??
Such a tough decision.. :confused:
B
baritoni
For TV and DVD use you don't get anything by investing in Full-HD. 37" doesn't even get any better than 1366x768 when watched more than 5 feet even on hd-dvd.
Only thing I can think of is if you use the screen for PC. Then you might consider full-HD.
L
lemel
Thanks baritoni, your right, i might use it for connecrtion to my laptop, but for now its just TV-DVD use, oh and for XB360... just got in the back of my mind that maybe i will get myself a HD player, possibily for the 360 so just dont want to limit myself for the sake of £100 you know...might kick myself later... :suicide:
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
