LG 32LX2R LCD Wall Bracket Needed --Help!
Discussion in 'Home Cinema Buying & Building' started by ddcookson, Sep 12, 2005.
  1. ddcookson
    ddcookson
    Just purchased LG 32LX2R LCD, need some help finding a fixed tight to the wall bracket suitable for this TV.
    All fitting and setup tips would be a great help for me.
    Thanks for your help.
  2. chic
    chic
    Jul 1, 2001
    5,975
    glasgow
    +871
    i have the LG RZ32LZ50 and i fitted to the wall using a standard vessa 100 mount which i used with my old 26 in lcd tv, i had to buy a 200mm convertor plate from ebay which i bolted the mount onto i then bolted this onto the tv. cost abou £40 all in. my old mount could hold a tv up to 20kg so the tv isnt heavier than that so i just needed the adapter plate so i could fit it to my tv. Ebay has lots of mounts for this tv
  3. freekbear
    freekbear
    I've got the 32LP1D and want to hook it up to one of these
    http://www.stil-stand.co.uk/site/20521.htm
    I contacted LG support to find out if it works with universal fittings, but all they had to say was (response was very fast < 1 hour, which impressed me):
    " The unit can be wall mounted using the RW200 wall mounting kit. This can be obtained through either your retailer or SEME Ltd on 0870 8721221"
    http://www.electricshop.com/invt/4000lge113648a&source=affiliatefuture
