LG 32LX2R and remote codes
Discussion in 'LCD & LED LCD TVs' started by pixelpixel, Aug 2, 2005.
  1. pixelpixel
    pixelpixel
    Jul 2, 2005
    13,377
    On da Internet
    +2,218
    Just got myself a LG 32LX2R 32" LCD HD ready. :thumbsup:
    Great bit of kit.The only problem. The remote and the lack of remote codes.
    I have sky+ hooked up to it.
    In the LG manual it says that you can use the LG remote to control my PACE sky+ box.
    In the sky+ box it has no record of LG. <Have checked Sky's website and found various codes.>
    LG - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275
    None of these works.
    Also found info that said LG also goes under various different names.
    Tried LG spin offs also Sony, Sharp + Phillips codes.
    Its a pitty that you spend money to have something annoy you like have both remotes with you at all times. Rather than like my old sharp 28".
    Please can someone help.!!!! - Have contacted sky they said contact LG, lg said contact SKY.
    Thanks for any advise! :clap:
  2. Moogrose
    Moogrose
    Aug 5, 2005
    142
    What are your opinions on the set pixel? -- have played any SD Xbox on it yet?
    Any info would be super fine... thanks.
  3. pixelpixel
    pixelpixel
    Jul 2, 2005
    13,377
    On da Internet
    +2,218
    What do you mean opinions on the set pixel?
    My xbox is a uk abox and its not chipped. But ISS Pro 5. Does look amazing. :eek:
  4. joggy148
    joggy148
    I have just after waiting for 2 weeks had a new sky+ box delivered along with a version 6 remote (old box died ) and was hoopeful that this would solve the problem you R having as my old remote was a version 5 unfortunately still no joy> I rang LG today was given a few new codes 0742, 0065, 0125 but no joy was told that I would have to wait until sky bring out a new remote.!!!!
