LG 32LP1D - any info?
Discussion in 'LCD & LED LCD TVs Forum' started by Chu321, Jul 26, 2005.
Tags:
Thread Status:
Not open for further replies.
  1. Chu321
    Chu321
    Jul 19, 2005
    54
    First post.
    I am in the process of trying to decide which 32" LCD television to buy. The advice on here is really useful but the only thing I am sure of is that I am going to buy one. It looks like the Hitachi (32LD7200) is favourite but I am not that sure and want to be as sure as I can that I am making the right choice. I have around £1200 to spend.
    Does anyone know anything about this LG model in particular (it must be new I think), or about LG as a manufacturer of LCD televisions? I cannot find much about them on here.
    I want the television for Sky/Freeview and DVD's and HD in the future. I can wait if I need to as I know a crop of new televisions are about to enter the market. Should I wait? I know you can wait forever but if something potentially very good in my price range is expected then I would like to be able to consider it.
    As much help or guidance as you can offer to clear my indecision will be much appreciated.
    Thanks.
  2. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    Yep, for that money the lg or samsung is the way to go...just check them out in the shops for looks etc. and make your decision, can't go really wrong with either :)
  3. juggysingh
    juggysingh
    Jul 26, 2005
    5
    Hi guys,
    I have researched numerous forums and websites on the best 32" lcd tv to buy. Initially i placed an order for the Samsung LE32R41BDX, as my previous judgement felt that it ticked all the right boxes for my needs, hdmi, dvb tuner, vesa compliant etc. However, after aquiring more knowledge and understanding within the realms of hd lcd tc's i have realised that the samsung may not be the ideal model for my needs as it does not offer any other input for pcs other than that of d-sub. I know i could use its only hdmi slot in-conjunction with a convertor cable (dvi to hdmi cable, as i have a graphic card with dvi output), but then i would not have the option of using that for other devices, such as next gen consoles & dvd players & sky box etc. Therofore, so far i feel that the LG 32LP1D ticks all the boxes; hdmi, dvi (for supported pc with dvi graphic card output), vesa compliance for using vesa devices for mouting, dvb tuner, component, pip, dual screen, and i can go on!! To be honest i dont thing their is a more comprehensive screen availble which will cater to virtaull everyones needs. But, and here comes the but, their is a quite hefty price tag, so far the cheapest i have seen for this unit is £1, 399 excluding delivery. Last comment, I am no expert, and dont proclaim to be on lcd tvs, just your average consumer who likes to check and research his products b4 he buys, therefore i welcome the more compitent members of the forum to add to any comments i have made. Afterall, my aim is just to buy the best hd lcd tv i can at an affordable price, look forward to your comments, thanks Juggy! :thumbsup:
  4. freekb
    freekb
    I bought it for £1379 from Ask (www.askdirect.co.uk or .com) in tottenham court. I picked it up from their shop - so no shipping charges.
    Quite happy with it - PC connectivity works spot on.
  5. freekb
    freekb
    Oh, at Ask also have a massive LG display stand doing the 32, 42 and 55 (50?) inch models and they will play back any source you bring in (I brought a laptop)
  6. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
Thread Status:
