Lg 32le4500 led SD HD
diamondnine
Hello
I have just got my mum one of the above. I dont know if its any good but she liked it. Anyway my question is how does she know if she is watching HD Freeview and not SD Freeview. If say Emerdale is SD then followed by Coronation Street HD will it default to HD or will she have to push a button on the remote. I have looked through the manual but cannot find the answer.
Regards
DJStarscream
The SD channels and HD channels are separate. For instance on BBC HD there will be a logo showing 'BBC HD' in the top left corner.
The HD channels are usually higher in channel numbers also. :)
diamondnine
Just had a look on Google and as you say they are higher numbers 50+.
Thanks for the help
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
