Lg 32lb1r
Discussion in 'LCD & LED LCD TVs Forum' started by noise0, Dec 24, 2006.
Tags:
  1. noise0
    noise0
    Dec 24, 2006
    24
    hi guys
    i am italian , and this is my first post
    i am about to buy this TV to use as HTPC
    i have read it perfectly maps 1:1 the DVI/HDMI input.
    i think the overall quality is fine, so i have decided for this model.
    well... have i to expet some minor bug form the LB1R in DVI/HDMI(HTPC) setup ???
    I am concerned about a bug i have noticed :
    the tv was connected to a video composite signal in a store..
    during the transmission, when the stage changes in the screen, it happens that shapes take a second to became crisp. It's like a nasty delay of the antialiasing/optimization algorithm. This effect is detectable only when the stage changes instantly ,expecially on sharp shapes like drawings on a board.
    other guys have noticed this bug so i am in fear: if this bug is present only with video-composite input i think it is acceptable .. otherwise it could be a big trouble for me ...:rolleyes:
    thanx
  2. noise0
    noise0
    Dec 24, 2006
    24
  3. marty2005
    marty2005
    Jul 22, 2005
    3,694
    Great Yarmouth
    +155
    If your that worried about it then don't buy it.
    Composite video is not that good but you shouldn't have any problems like you are describing.
    The fault maybe with the input source the shop was using and not the tv.
    Happy xmas.
  4. noise0
    noise0
    Dec 24, 2006
    24
    the problem was not in the shop, because italian forumer have recognized this fault at home with this tv. the problem appears seldom and is not clear if it depends by the conection used.
    So i posted here to check your experience about this bug.
    no one recognized it? :confused:
    is there any alternative for a good 32 which maps perfectly the DVI/HDMI input from a PC?
  5. noise0
    noise0
    Dec 24, 2006
    24
    i make this last attempt to gather opinions on this model
    thanx
