paulm10
Hello,
I'm thinking of buying the LG 28TN525S Smart TV from my local Richer Sounds and have some questions about it.
I'm planning to use this stand with the TV. Amazon product ASIN B082845WXQ
I'm slightly worried that the vertical part of the stand will block me from inserting the cables in the back of the TV.
Does anyone else use this (or simular) TV and have a simular stand? Does it interfere with any of the input/output sockets on the back?
I think the TV looks great and has many good features, but I have some concerns about a few of them.
As the TV only has 2x 5watt speakers, Does this make the sound really bad?
I've learnt that this TV doesn't come with a full comprehesive manual (only a 20 page set up guide!). As this is my first Smart TV, I would of appriated a full printed manual. I bet Smart TV's have TON of settings! Given the lack of a manual, Is this TV easy to learn?
Two final questions,
I thought most modern TV's were supposed to be energy efficient. How come this one is labeled as F? I thought it would have been higher.
Is it worth buying a LG 2022 Magic Remote to use with this TV or just stick with the supplied remote?
Thanks for all answers.
