D
Daley1
Ok my xbox 360 connected to my LG 26LC2R through Component produces overcan, I managed to get into the service menu of my TV (holding menu on tv and remote) and decided to fix this overscan problem.
After noting down all the values I came to overscan which is set at 2 (max value) which produces 7% overscan, no matter if I changed it to 1 or 0 the overscan remains the same, the screen jutters slightly when it is changed for a split second but the amount of overscan on screen is no different (even though in the menu it says it is now set at 1%).
If anyone could help it would be great, thanks.
