LG 2300p multi region
Discussion in 'Blu-ray & DVD Players & Recorders' started by Taz, Apr 5, 2001.
  1. Taz
    Taz
    anyone know why the LG 2300p DVD cant be made multi region unless its sent away to be modified? dose antone know of a DIY kit?
    CHEERS.
  2. simes
    simes
    DIY kits are available at www.dvdchips.co.uk for £20.
    I am assuming your player is either the 2330 or 3200 (never heard of the 2300 !! )
  3. Taz
    Taz
    Simes thanks for the reply, (you were right 2330p) I checked out there site and the only DIY kit they do for my LG is to disable macrovision for multi region its.... off to them for £60 + P+P so thats around £80 again. any other ideas? TAZ. :confused:
  4. Jay2000
    Jay2000
    try this hack
    Its the same hack used for the 3300 series players but it also worked on my old 2330P although I suspect it was already chipped before I bought it. Give it a try though, I know for a fact that certainly 2330P's bought at Richer Sounds were pre-modified and maybe some bought elsewhere too. What you got to loose! Good luck.
    Jay
    [ 07-04-2001: Message edited by: Jay2000 ]
  5. Taz
    Taz
    Jay, thanks anyway but it didn't work!
    Taz. ;)
  6. simes
    simes
    Most of the mods are software ,thats why there is no DIY option.
    If you do decide to send it away for modification then i recommend www.upgradeheaven.co.uk
    They will do the upgrade for £50 including return courier shipping.
    To get it for this price you need a printout of the page on the link below http://www.dvdtimes.co.uk/uheaventoken.html
    If you go on the website the price including collection,modification and return delivery is £69.
