Is this LCD primarily a TV or a Monitor & can I connect my PS3 to it & play hi-def games & Blu-rays fine?
You can do that with no problems, obviously it wont look as good as on a big high end LCD/plasma, but it wont look any worse than any of the other TVs around the same price and size
It accepts a 1080p signal, but it only displays 720p, I'm assuming you've pressed the 'ok' button on the remote and seen that it says 1080p, that means the input signal, it's actually downscaling that to 720p to display on the screen.
Because the PS3 does take the screenshot at 1080p, it doesn't take what the TV is displaying, it takes what the PS3 is sending, which is 1080p. It may well look better because the resolution of the TV isn't exactly 720p, with the numbers it's actually a bit easier to scale down from 1080p to the res of the TV than it is to scale up from 720p
so why it will not upscale 720p games to 1080p?
you see all native 1080p games play at 1080p
i set ps3 to display 576p and 1080p and it downscale Uncharted to 576p but native 1080p like GT5P stays at 1080p, it will not get downscaled to 576p.
Is the stand easily detachable?
