LG 22" tele tuning problem
Hugh Ashworth
Hi, new to the forum, hope someone can help. I have bought a new LG 22LH2000 TV today and can't get it to tune any of the digital channels. I've gone thru auto set up to no avail and can't figure out whats up. I did try a set top box in through the scart and that worked fine so tv is Ok just can't access freeview. We can only get a handful of channels and reception is poor.............can anyone help??
square-eyes
It sounds like you are not getting a good signal into the LG TV. Make sure the coax plug and socket are clean. Perhaps try a bit of switch cleaner spray. If that doen't cure it then get the shop to replace the TV as it is faulty.
