LFE on Denon 3802 in DPL II mode
Discussion in 'AV Receivers & Amplifiers' started by jspone, Dec 9, 2001.
Tags:
  1. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    Does the Denon 3802 not output to the LFE channel in DPL II mode?
    In the speaker configuration section of the set-up menu, I’ve selected LFE only (rather than LFE + Main). As I understand it, this should only steer the LFE channel of a 5.1 sound track to the subwoofer. When listening to a 5.1 soundtrack it sounds fine.
    When I then play a disk without a 5.1 soundtrack, the amp switches to DPL II and nothing is sent to the subwoofer. This seems strange, because there is a LFE parameter in the DPL surround parameter menu.
    Am I missing something, or do I have to keep switching from LFE only to LFE + main?
    John
  2. Raj
    Raj
    John,
    On mine with LFE setting, the subwoofer only works in DPL II Cinema Mode, with DPL II Music mode, the subwoofer is definately off and not sent any signal by the 3802.
    So with DPL-II Cinema mode, you should get something from the subwoofer, assuming that there is some signal on the .1 channel.
    Have you tried this with various materials, also try temporaily turning up the sub while testing and make sure you're using DPL II Cinema mode.
    Raj
  3. Lowrider
    Lowrider
    Did you set the front speakers as small ? If you didn´t you probably wont get anything from LFE using DPLII...
  4. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    Guys, thanks for the input
    Raj, I have been using DPL II in Cinema mode. When you say "you should get something from the subwoofer, assuming that there is some signal on the .1 channel", the point is, if I'm lstening to a Dolby stereo soundtrack, there's is nothing on the .1 channel. I expected DPL II to create one 'on the fly'.
    In the Speaker Configuration menu, have you set the subwoofer to "LFE" or "LFE + Main"?
    Lowrider, I've set my front speakers to "Large". Everything works fine in true 5.1 modes. It's just DPL II where the subwoofer is dead.
    John
  5. Raj
    Raj
    John,
    Not sure of DPL II creates a .1 on the fly or not, it's an interesting question if someone can answer this.
    I have my sub set to just "LFE". But remember, the bass from any speakers set to small should also be redirected to the sub.
    I have my main L+R set to Large, all others set to Small. In Cinema mode I definately get output from the sub, but in Music mode I get nothing.
    Have you tried both Cinema and Music modes of DPL II ?
    Raj
