LFE Extension Cable
Discussion in 'Home Cinema Speakers' started by HDPete, Jan 20, 2004.
  1. HDPete
    HDPete
    Jan 15, 2004
    281
    Ringwood, Hampshire / Dorset Border
    +14
    I need to run a cable approx 6m to the other side of my room for my sub (Active 10" Gale)
    Does the quality of the cable matter as it is only delivering LFE?
    I already have a 10m cable which is fine, but I'm running the cables in the ceiling and once in, they aren't coming out!
    Pete.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    The quality of cable is less important than normal speaker cables but I would suggest that if you intend to upgrade your sub at all that you think about buying something a little better than the bellwire freebie
  3. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    I would suggest some RG59 (75ohm) cable and a couple of decent phono plugs. Easy enough to get the parts from Maplins and make the cable as long as you want.
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Pete
    If you are running the cable in the ceiling will it be close to existing 240v cables as poorly screened (cheap sub cable) could suffer from hum.Just a thought as you would be pulling your wig off if it did.
    Cheers Gonzo.:)
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    We tested a few subwoofer cables with a Quake the other day, there where large differences in bass quality, the QED QS something and the Audioquest G-Snake where way ahead of the other budget cables... :eek:
  6. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I've never heard of a G-Snake. Is it anything like a Trouser-Snake :D
  7. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Thinner than mine... :p
    http://www.audioquestmusic.com/
  8. chips
    chips
    Dec 3, 2001
    2,380
    41
    2NM S EGTF
    +22
  9. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    I made mine from some satellite co-ax and a couple of RCA plugs.
    Works a treat and the best part is, it's exactly the length I wanted. :)
  10. HDPete
    HDPete
    Jan 15, 2004
    281
    +14
    Thanks all for your advice - the hum I'm getting at the mo will be the crap lead being too close to the mains then!?
    I'll make doubly sure that the mains is seperate.
    Thanks all.
    Pete
