Lexicon DC2 hot stuff!
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by garyc, May 18, 2003.
  1. garyc
    garyc
    Dec 21, 2002
    866
    Jersey, Channel Islands
    +13
    Could any other Lexicon DC2 (or maybe DC1/MC1) owners confirm that left hand side/front of the unit gets really quite HOT after its been on for a few hours or is it something i should worry about?
    cheers
    Gary
  2. nathan_silly
    nathan_silly
    Just warm, not hot.
    MC-1 owner. Have you got a few inches ventilation?
  3. garyc
    garyc
    Dec 21, 2002
    866
    +13
    No really!! stand is max'ed out!!
    have a few inches either side, but only about 5mm on top under the next glass shelf.
  4. Bruce123
    Bruce123
    Jul 25, 2002
    128
    Wandon Green
    Just checked my DC2 and whilst the left hand side is noticibly warmer than the right it is not hot. In fact the rear of the unit is warmer than the front. It has been on for over 8 hrs now. I hope this does not spell trouble for you.
    Bruce
  5. nathan_silly
    nathan_silly
    The power supply is on the left.
    You need more than 5mm ventilation though!
  6. garyc
    garyc
    Dec 21, 2002
    866
    +13
    Thanks guys,
    Will try and get something moved out of the rack to increase the top ventilation to the lexi.
    and hope nothing is wrong
