Lexicon DC1 DAC's
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by rigman, Feb 9, 2001.
  1. rigman
    rigman
    Dec 14, 2000
    2,970
    83
    East Yorkshire
    +115
    does anyone know how you can tell if your Lexicon DC1 has 24 bit or 20 bit DAC's
    thanks
  2. Charlie Whitehouse
    Charlie Whitehouse
    I believe you can tell by the serial number. Try going to www.smr-forums.com ( the de-facto fount of all wisdom for Lexicon products) and do a Search on 'serial number' on all forums and you should find a discussion on this topic. If you have any further questions, I'm sure they would be only too happy to help over there.
    "Miiiinnnd the doooors!"
