Quantcast
Lex not happy about Phillip Dick adaptations, try this!
Harj
Had the fortune of watching Imposter on sky movies a while ago, its another Phillip K Dick adaptaion and in my opinion up there with Blade Runner and Minority Report, a very underrated film, Gary Sinise gives an intense performance.
Similar feel to minority report, no doubt if it had bigger stars it would have been a bigger film, got the DVD for £5.99 , can't remember where from though!
Has an ending ;) know what i mean??
Harj
And don't go by IMDB ratings, this is one of the many occasion where the ratings do no reflect the film.
bjd
It's Impostor, not Imposter :) in case it doesn't come up in a search. £4.49 at Play
dfield2000
Isn't there supposed to be a new Phillip Dick adaptation being made ? I can't remember the director, but I think it's someone usually associated with action films - maybe Woo ?
Rambo John J
so which is the UK version of Impostor, as in "how long is it"? The R1 directors cut disc is 102 minutes and R rated, the only listings I've seen for the 15-rated R2 have it clocked at 91 minutes, the shorter US theatrical PG-13 version.
As the R1's only about £6 I've gone with that (£6.82 delivered @ Pacific).
Harj
cant explain the differnce in times for R1 and R2, though when i researched the editions I did not notice anything about cuts, but the R1 version does have the original short film (with the same actors I beleive) that got extended into the feature lenght.
Let us know what you think of it.
Lex
Thanks for the recommendation Harj - will check it out :smashin: It's gotta be better than Screamers :rolleyes: :D
Similar threads
