Lethal Weapon 1 Directors Cut DVD
Discussion in 'Movie Forum' started by tayke, Jun 16, 2004.
  1. tayke
    tayke
    Don't know if I'm in the right forum for this but here goes...
    Pulled the above DVD off the shelf for a look last night only to find it was 'sticky', with a pattern beneath the layer of the disc. Completely unplayable. Has anyone else had this problem?
    If so, who did you contact?
    Thanks,
    Tayke
  2. Setenza
    Setenza
    Jun 17, 2002
    3,349
    +226
    Sounds like DVD rot. IE he glue bonding the two layer together has reacted with a contaminant.
    Try contacting WB UK.
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    The same thing happened with the first batch of terminator dvds. Because there were so many complaints a help line number was printed in dvd review and if you sent the disc back they replaced it for you. Dont know if warner will do it for this one though, it depends if there are a lot of people with the same problem.
  4. tayke
    tayke
    Visited the WB site which seems to have everything except an email address?
    Can anybody point me in the right direction?
    Thanks,
    Tayke :thumbsup:
