Less bright after signing in to xbox live?
lapino
Any1 else noticed this? I have my 360 connected to my 26" Sony LCD through VGA. When the xbox360 boots, colours are very bright. The moment I sign in to xbox live though, the colours are muted quite a bit.
Leighboyuk
I noticed this on a Sony Trinitron Sd through RGB.
Mr Quint
Depends, what are you useing as you Dashboard background?
If its a darker pic than the screen you get just before auto sign in then it will seem to go just a tad darker.
Try going into themes and setting it back to default background then sign in and out of live and see if it still does it.
Just i thought but i might be wrong, let me know. :)
lapino
I have never changed the background. Someone else said this is due to the live login profile, but there's nowhere to set a brightness. Strange...
Similar threads
