Leon Superbit a Failure ?
Discussion in 'Movie Forum' started by FoxyMulder, Aug 23, 2003.
  1. FoxyMulder
    FoxyMulder
    Just read this review, i have the extended cut from a few years back and was really wanting this as a superbit suffice to say i WILL NOT be buying it now.
    http://www.dvdfile.com/software/review/dvd-video_7/leon_sb.html
    Seems the transfer doesnt improve much on the original release in particular the sound mix is worse.
  2. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Hrm. I have the original, cut, R2 and have this superbit on pre-order. I think I'll buy it anyway, it's cheaper than the older uncut edition and has better video. The difference in audio sounds small and the missing extras are not significant IMO. A bit disapointing though.
    Thanks for the heads-up.
  3. FoxyMulder
    FoxyMulder
    I always wondered why my extended edition version of Leon which i bought a few years back had little bass and poor surround activity, i put it down to it being a remix but it seems the truth is that an initial batch were faulty and i happen to have bought one, i got mine off Play247 from Jersey, i have emailed them today saying i would like a replacement since i was not to know initial batches were faulty and isbn numbers beginning with 4 on the top right side of the box means your version is defective.
    Does anyone know if Play will replace my copy after 2 years +
    http://www.hometheaterforum.com/htforum/showthread.php?s=&threadid=18328&highlight=leon
    This also brings up the possibility that the Superbit version is defective and will be quietly recalled, that won't help anyone who's bought it and is unaware of the problem and thinks the inactive surrounds and poor bass is normal.
  4. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,147
    +683
    They replaced mine after I had it for about one year!
