lens throw?
Discussion in 'Projectors, Screens & Video Processors' started by upallnight, Dec 10, 2004.
  1. upallnight
    upallnight
    Jun 11, 2003
    1,816
    63
    watford
    +106
    helllo all
    has anyone ever had a problem with the fact that the throw distance of there pj does not zoom far enough for preffered screen size (room not long enough)
    is there a solution to this?
    some kind of lense to enlarge throw etc?
    thanks
  2. AMc
    AMc
    Nov 20, 2000
    6,827
    Near Norwich
    +3,402
    Assuming that you want a smaller image then there are lenses available for some of the projectors (search for long throw lens) but they're really expensive.
    It may be more economic to sell you PJ and buy one that suits your room.
    Or look at ceiling/coffee table mounting nearer the screen.
    I spent a lot of time looking at the calculator over at www.projectorcentral.com before I chose my PJ as my throw distance was very long for home cinema.
