Lens shift - affects focus or keystone?
Discussion in 'Projectors, Screens & Video Processors' started by Snoopstah, Jan 2, 2005.
  1. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Hey,
    Can anyone tell me if using the lens shift affects 'angle' of the picture?
    I.e. if I have the projector high up, and the screen low down, but with the projector aligned perfectly horizontally and screen aligned perfectly vertically, do I need to use the keystone adjustment to get a square picture? And will the focus be the same across the height of the screen?
    Projector is an Panny 700, if that helps.
  2. Sporran
    Sporran
    Dec 13, 2004
    1,486
    Pembrokeshire, Wales
    +135
    i just got a HS50 and am literally sitting the PJ on the box it came in, bout 12" off the floor and the bottom of the projected image is around 45-50" inches off the floor. I am using considerable lens shift and needed to give it some keystone adjustment to make it appear square and now the picture is spot on. So i guess the angle will affect the keystone. Cant see that it has affected the picture in anyway. Though im no PJ Pro.
    Need to sort a screen and mount out ;)
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    I use both horizontal and vertical lens shift on the TX100 to align to my screen and it doesn't introduce any keystoning (is that a word? ;) ) - the manual does say that any deviation from the centre position may degrade the picture slightly but I haven't noticed...PJ
  4. Snoopstah
    Snoopstah
    Mar 17, 2004
    42
    Thanks guys - just finished building my DIY screen, and it's perfect - only needed a small amount of lens shift, but no keystoning effects and perfect focus all the way across! Lovely :)
