Lens Cleaner
Discussion in 'Arcam Owners' Forum' started by raven219, Mar 3, 2005.
Tags:
  1. raven219
    raven219
    Mar 5, 2001
    544
    East Anglia (well someone has to live there!)
    +19
    Thinking of getting a Allsop lens cleaner kit for a CD walkman, and it got me thinking about my DV88+. Should I run the cleaner through this? And is there any difference between a CD cleaner and a DVD cleaner?
    Raven
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    Absolutely none whatsoever. I recommend getting the Allsop Carbon lens cleaner, have been using one for years and it works a treat. It also helps to remove static from the leser mech.
    Allsop Ultra Pro Lens cleaner
  3. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Any idea where to pick one up in the UK? Not seen this one before! :smashin:
  4. IanDH
    IanDH
    Put it into google and got 179 hits from the UK - choice of suppliers @ £14.95 - one of those things that you add onto another order to keep down postage.
    Ian
