Lens advice
Discussion in 'Photography Forums' started by werewolf40, Sep 3, 2007.
  1. werewolf40
    werewolf40
    Jul 30, 2006
    532
    28
    Milton Keynes
    +76
  2. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    If it fit a 20D it will fit a 350D.. they both have Canons EF fit
    Is it worth £200?
    Im not sure although I like the f 2.8
    After using the Sigma 70-300 DG APO ( albeit with f4.5) ,I would rather buy one with IS though . Im not sure how much more that would set you back.
    IS and a fast Zoom would be the ideal but that would be so much more expensive.:D
    Maybe someone who has one on here can comment on the value of the lens
  3. werewolf40
    werewolf40
    Jul 30, 2006
    532
    28
    Milton Keynes
    +76
    Thats my problem is it worth that sort of money,but i to like the f2.8 what to do,what to do.Thanks anyway senu.
    EDIT: also i was thinking about using this lense with my x2 tele converter,would it still auto focus ok,or would it have problems???
  4. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Looking at its picture again, I'm rather a little apprehensive of putting that on a 350D.. it looks long and heavy!!:eek:
    Im almost sure the answer to the teleconverter is at best .. probably: If it was a Canon Id say Definitely
  5. werewolf40
    werewolf40
    Jul 30, 2006
    532
    28
    Milton Keynes
    +76
    Ok thanks again senu.Really dont know what to do now.Cant afford to get one with IS,so guess ill just keep looking:rolleyes:
  6. jonnypb
    jonnypb
    Dec 4, 2005
    4,130
    Cumbria
    +559
    hmmm it's listed at £200 buy it now, it may go for alot less though. It looks kind of an old lens and not one i've seen before so can't comment on it.
    I'd be tempted to sell your 75-300 which you have in your sig and save for either the 70-300IS or 70-200 f4
  7. werewolf40
    werewolf40
    Jul 30, 2006
    532
    28
    Milton Keynes
    +76
  8. AceAceBaby
    AceAceBaby
    Mar 5, 2007
    323
    +22
    That lens is about £370 new on OSD, so £310 doesn't seem bad at all if it's in good condition?
  9. werewolf40
    werewolf40
    Jul 30, 2006
    532
    28
    Milton Keynes
    +76
    Ok thanks for that:thumbsup:Stupid question but is it a GOOD lens:confused:
  10. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    I dont think there is any bad "L" lens TBH.:D
    70-200 f4L is widely regarded.. Its F2.8/ ( IS) version even more so
  11. werewolf40
    werewolf40
    Jul 30, 2006
    532
    28
    Milton Keynes
    +76
    Didnt think there was senu just wanted to hear it from the experts:DThanks for your help guys:smashin:NOW to see if i can afford it(well im only 50 quid short,but 50 quids alot when you dont have it)
