Lens Addition for AE100
Discussion in 'Projectors, Screens & Video Processors' started by rthorto1, Dec 18, 2002.
  1. rthorto1
    rthorto1
    Is anyone aware of an additional lens which can be attched to the 100? My problem is the throw distance, which i need to be 4.3 m from pj to screen, however my screem size is 7 foot.
    The image size at that distance with the zoom at minimum is roughly 8.5 foot!
    I do not want want to move the pj if i can avoid it as i have the perfect space in the wall to mount it?
    I need a lens that can reduce the image to fit?
    I have tried panasonic and a couple of local camera shops but nothing so far? it must be possible to attach a telefoto lens, there is a thread on the lens 55mm, presumably for a filter?
    Has anyone encountered this problem?
    I would much appreciate any help!:confused:
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,495
    Windsor
    +1,051
    not that I know of. I think the AE300 comes with optional ultra-short and long throw lens attachements. Doesnt' really help though.
