Hi all I have a work laptop I suspect it is the following model
lenovo 20jtsor600
I want to know have three screens connected to the laptop but would I require a docking station like a Lenovo thunderbolt - can someone please kindly advise?
Hi thank you for the reply, I will try and have a look on the Lenovo website to see if I can scan the model. I'm not too sure if I can find this info whilst logging on the laptop.20JT appears to be the internal name for the Thinkpad T470s.
I couldn't find the exact configuration that the rest of the name will refer to listed on lenovo's website. It could be a typo or it may not be listed.
But looking at the other T470s configurations they're generally listed as supporting three independent displays and having USB-C and HDMI outputs.
It doesn't go into details as to whether there's any combination limitations but HDMI only supports one display so DisplayPort (USB-C almost always refer to DisplayPort Alternate Mode) would be the way to go.
The functionality you need for connecting multiple monitors to a displayport output is called an MST Hub. A USB-C (or thunderbolt) dock will generally incorportate that along with additional functionality like a USB hub or ethernet or sound hardware.
So you don't strictly need a dock, but its likely the simplest and cheapest solution these days.
The two monitor screens I have is a Illyama pro lite xub2492HSU.....Thunderbolt adds extra functionality to USB-C but I believe it is compatible with all USB-C stuff so it would work. But the extra thunderbolt stuff is not supported by your laptop and makes it more expensive. A thunderbolt dock is probably not a good option unless you envisage work giving you Thunderbolt equipment in future.
What resolution and what connections do your existing two monitors have, and what resolution would the third be?
Thank you for the reply20JT appears to be the internal name for the Thinkpad T470s.
That should work, although that one only had two video outputs so you might want to look for one with three if you find the current setup messy.Thank you for the reply
Something like this?
I'm not much of a gamer tbh, and this is all for work purposes more than anything.That should work, although that one only had two video outputs so you might want to look for one with three if you find the current setup messy.
The combined resolution of all screens is limited to the maximum supported by the USB-C output but your current ones aren't particularly high so that shouldn't be an issue unless you wanted a very high resolution third monitor.
