Length of Component Cables
Discussion in 'Cables & Switches' started by Barnoonan, Mar 21, 2005.
  1. Barnoonan
    Barnoonan
    I have a DVD that I want to connect ot my new Panasaonic AE700 projector.
    I want to use component cables but I am concerned about the length I need.
    Probably about 10m.
    I have read a tonne of stuff about impedence etc but don't really understand so what I want is a simple answer.
    Will the length be a problem if I spend about £60 on IXOS or Profigold cables?
    Anyone got any suggestions about a better make? I don't really want to sepdn £200 as I am unlikely to notice the difference.
    Thanks in advance
    :lease:
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,073
    The Borders
    +2,529
    Barnoonan
    Assuming that your DVD player has YUV Component 'Out' - not all of them do; though some folk assume they do :)
    Look in the Power Buy section for Mark Grant cables or do a search for VanDamme Red Series cables - you'll pay a bit more than £60.00 for a decent 10m set and yes you would 'see' a visual difference between these and less well engineered/manufactured cables.
    Best regards
    Joe
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Barnoonan,
    Got to agree with Joe. I have one of Mark Grant's 10m component cables to my infocus 5700, and it is a really good picture. I am just using it for my XBOX with progressive output, as my DVD is connected via HDMI, but it is still a supurb picture. Can't recommend Mark enough for service and quality cables. By the way, his 10m one is £140 delivered! :)
