Length of cables V Picture Quailty
Discussion in 'Cables & Switches' started by Ponty, Sep 22, 2005.
  1. Ponty
    Ponty
    Feb 15, 2005
    68
    I've just received my 3m IXOS611 Flat scart to wall mount my plasma and I'm getting paranoid that the PQ looks worse than the 1m Flat Monster cable that I currently have (£30 reluctantly @ Comet)....
    Question is
    a) Do you rate the IXOS cable above the Monster ?
    b) How much does cable length affect the perforamance of this quality of Scart and do I need to spend more?
    I could get away with 2m, but this will make the install more difficult as I'll have less slack?
    I've also bought a 3m Mole HDMI cable, will this also suffer?
  2. Ponty
    Ponty
    Feb 15, 2005
    68
    bump
    Anybody?
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,556
    The Borders
    +3,026
    Hello Ponty
    Price is no indicator of a good or bad cable - Tech specs are what counts; though its often difficult to extract them from the manufacturers.
    Its perfectly feasible that your 3m cable is degrading your signal compared to your 1m cable - the only way to test it would be to purchase a Test DVD (AVIA or DVE) with some Test Patterns on and look at the patterns via both cables; Do the patterns look less sharp via the longer cable? If Yes you need to ditch it!
    I'm guessing you have a 3m MOLEX HDMI cable - if yes then you should be fine with that cable - Digital cables can and do make a difference though the Molex are well made for the money.
    Best regards
    Joe
