Length of cable ?
Discussion in 'Cables & Switches' started by DragonMaster, Mar 24, 2002.
  1. DragonMaster
    DragonMaster
    The distance from my AV amp to the left speaker is 6ft
    to the right speaker is 10ft
    can I use a 6ft and a 10ft cable ? or do they both have
    to be the same length ?
    Best Wishes
    [email protected]
  2. Timh
    Timh
    Sep 14, 2000
    5,224
    3
    3
    Altair-4
    +310
    According to the HI-Fi mag's you should always keep the speaker cable's the same length.
  3. mjn
    mjn
    May 24, 2001
    22,724
    Herts, England
    +10,868
    its not going to make a difference, when you consider how fast sound travels....especially over 6 and 10 foot
  4. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    mjn,
    I agree, and even if there was a difference (presumably the volume level dropping?) you could make adjustments with the amp.
    DragonMaster:
    I have 10 meter (surround right) and 14 meter (surround left) cable runs with no discernible difference in audio levels/qualities.
    Try it, listen, adjust and be content.
  5. Darth Vader
    Darth Vader
    Feb 13, 2002
    102
    16
    Middlesex
    You won't get volume drops with the length's Dragon Master is talking about, most good quality speaker cable will lose only a few dB's per kilometre!.
    The only other issue is "phase" problems ,where one speaker gets the sound information a fraction before the other(s), this would be a problem if one cable length is really short and the other is really really long. but in these circumstances it should not be a problem.
    Dragon Master.
    I agree with most of the other posts, at the lengths you are talking about you should have no problems using different cable lengths.
